bigjohn67 said:If I may add my thoughts,
Be careful with switching a GFCI outlet. They trip when power is lost. Such as the Leviton. If you are going to switch outdoor outlets, besure to use a GFCI breaker or outlet ahead of the switch.
That is profoundly untrue.bigjohn67 said:If I may add my thoughts,
bigjohn67 said:They trip when power is lost.
Sorry, John, but MD is correct. They won't reset without power, but they won't trip; if they were set before the power is lost, they'll stay set.mdshunk said:That is profoundly untrue.
There is a failure mode of certain GFCI's that can cause them to do this. 'Eagle' brand was somewhat infamous for this. A properly functioning GFCI will not trip when power is lost. This was such a problem with early generations of GFCI receptacles that the urban legend "you can't switch a GFCI" was developed and persists to some extent. It is only a screwed up GFCI that will trip when switched, and modern GFCI's seem to be immune to this trouble.georgestolz said:There was a brand that tripped when switched, but I can't remember when or which it was. It was three years ago, I think, when I saw it with my own eyes.
I know Coopers do not. They might have in the past.
Rockyd said:
LarryFine said:We recently had to add receptacle circuits to a garage
