What is the most efficient way to rough in wiring and later install receptacles in the back of cabinetry for built-in appliances?
In the past I have just left whips and then come back and cut in the receptacle. But it's a pain because you're hunched into the cabinet opening doing the work. This gets tiring if there are a lot of them. Is surface mounting them acceptable? if so, this would be way less of a headache.
What's the best method here?
