I am installing a hot water recirculation pump in a commercial space and need to include a remote thermostat to control the pump. The thermostat is to monitor the temperature at the farthest hot water fixture; it turns on the pump when the water cools at that fixture and turns off the pump when the water at the fixture is hot again.
I believe it is acceptable to route the MC cable (controlling 120VAC power from the thermostat to the pump) alongside the water piping that returns the recirculation water from the remote fixture to the recirculation pump. The piping is 1/2" PEX enclosed in foam pipe insulation and will be suspended above the grid ceiling by hangers spaced at 32" intervals. I intend to zip-tie the MC cable to the outside of the pipe insulation and run it through the same hangers supporting the pipe.
Is there anything in the NEC that prohibits such an installation? Or are there other reasons why this would be a poor choice for the installation?
