JUSTEINEE
- Springfield
I have a situation where a single phase 277VAC circuit is being routed from a panelboard to a load. The conduit exits the panelboard and is routed along the ceiling. We have a disconnect that is mounted approximately 5 feet below the conduit run is routed along the ceiling. The contractor has dropped a single conduit to the disconnect and has only routed the ungrounded "hot" conductor to the disconnect along with an equipment grounding conductor.
My question is does the neutral need to be routed with the phase conductor to the disconnect. I know that the neutral would serve no purpose but i have always had it in my mind that all of the circuit conductors have to be routed together. The code section i would fall back on is 300.5 (I) in the 2017 version of NEC.
The thing that has me wondering is i know on lighting circuits it has been standard practice to not route a neutral to the light switch (code now requires a neutral or the ability to add a neutral).
What are your guys thoughts? Please provide code references so that I can do further research.
