ryanman0
Greetings,
A rooftop antenna is grounded via 6AWG solid copper GEC (in Schedule 40 PVC) running down the roof and exterior of the one story home to a 10' rod. This is not presently connected to the intersystem bonding termination bridge. We are about to perform a Main Panel replacement and need to interconnect this per 2008 NEC 250.94. The challenge is that almost half of the home is surrounded by concrete. After a couple of failed attempts at boring a pvc run under a 30 foot driveway through extremely dense clay, we are considering other options for the bonding inter?connection.
Can we simply Run 4AWG solid copper in schedule 80 PVC up and then horizontally against the side of the brick building. There is a garage door that we would have to go on top of to do this. The distance of such a run would be almost 50 feet with 30 of these feet being horizontal runs just under the eves and around the corner towards the bonding termination bridge. 4AWG was being considered to reduce voltage drop on the long run. If not, should we just cut the long run into the concrete of the driveway and around the corner, lay down pvc, concrete over it. Any other options?
Also, the RG6 coax cable entering the building from this antenna down towards the television has a separate ground wire attached to it. This wire is also connected to the mast. However, the wire is presently not connected to anything on the other end inside the home.
Thank you,
Ryan
Thank you,
Ryan
