threephase
How many people use insulated gloves when changing/tapping/splicing into a dwelling service?
I do, along with FR shirt and trousers, rubber sleeves, dielectric overshoes and arc flash shield. OSHA rules don't happen to apply to me. They certainly might to most people.threephase said:How many people use insulated gloves when changing/tapping/splicing into a dwelling service?
Simma down, it was only for a picture. Actually, I suited up like that to flip the switch behind me.edamico11 said:No so sure I like the pen in the pocket, or the metal belt buckle:grin:
OSHA rules only apply to employees.Tori said:OSHA rules don't apply - just curious ,why not , are you not a US resident ?
mdshunk said:OSHA rules only apply to employees.
The violation there is the fact that you exposed employees of the factory to a hazard.emahler said:try leaving the cover off a live panel in a factory as OSHA walks thru, tell me if they care whether you are an employee or an owner...
stickboy1375 said:My brother-in-law works for poco, gave me a nice pair of high voltage rubber gloves, I use a pair of leather gloves on top of those, I only use them for residental service Cut & Reconnects, which we are allowed to perform...
Interesting.mdshunk said:OSHA rules only apply to employees.
For working at the voltages the dwelling services operate at, there's no need. Blow air into them at the cuff, roll the cuff over a few times to trap air, and see if there's any leaks. From a practical standpoint, a pair of leather gloves are suitable for 120/240 services. If you're working in the kilovolt range, you'd certainly want dielectric tests of your rubbers. The POCO's sometimes do those as a customer service for electricians and plant maintenance personnnel.FNCnca said:Do you have them dialectrically tested regularly?
Find a place where NFPA 70E has the force of law, besides as referenced in OSHA material. ...don't believe there is one.Dave58er said:Interesting.
How about 70E?
mdshunk said:For working at the voltages the dwelling services operate at, there's no need. Blow air into them at the cuff, roll the cuff over a few times to trap air, and see if there's any leaks. From a practical standpoint, a pair of leather gloves are suitable for 120/240 services. If you're working in the kilovolt range, you'd certainly want dielectric tests of your rubbers. The POCO's sometimes do those as a customer service for electricians and plant maintenance personnnel.
Every POCO has different procedures on that. You need to call yours and ask how they handle that. I work at the intersection of 5 POCO's, and they all have slightly different rules. For a couple, you schedule a disconnect for first thing some morning, tell the lineman when he cuts it off about what time you want him to swing back for a retap. Some want you to do the whole disconnect and reconnect yourself. Some want you to disconnect yourself, then call for them to stop over for a reconnect. Some you disconnect and reconnect temporarily, then call them and they stop over and take off whatever taps you used and they put on their preferred type. Just call your POCO and ask. The wiring in the mast is normally the customers, but some utilties here and there do that work. Anything's possible. If you already have a rapport with your local inspector, just ask him. He should have a good idea what the procedure is in your area.threephase said:So are electrical contractors as a rule allowed to change the wiring in the riser? masthead?
If doing so, the EC would be the one cutting & replicing into the service.
If this normally allowed without notifying POCO or are they responsible?
