ModbusMan
- Cleveland, OH
- Building Automation Engineer
Curious if anyone has seen this, or if perhaps my local Home Depot has seriously dangerously botched things up...
Twice now, I've rented a Rug Doctor Mighty Pro X3, and attempting to power it from either the general basement receptacles (dual-function CAFCI/GFCI) or the dedicated washing machine circuit (GFCI only) results in immediate breaker trip. Power it from the panel convenience outlet (which has zero "smarts") and thing thing runs fine for as long as I need it. All circuits in question are 20A. The only thing I can think of offhand that might explain this is that the plug on both machines (and I was given a different one each time) appears to have been replaced at some point, unless Bissell is in the habit of not using molded plastic plugs, and whoever at Home Depot did the work accidentally reversed the neutral and ground leads. I plan on reporting this when I return the machine tomorrow morning rather than disassembling the plug myself (and opening up who knows what kind of future liability issues), but figured I'd ask if anyone here's seen the same/similar, or if I might be missing something else that should have been obvious.
