run blower fan from VFD - potential issues ?
George C
New member
United States
i want to use this blower:
https://www.globalindustrial.com/p/...pi-portable-blower-fan-belt-drive-swivel-base
or a 3 phase version of it ( which is slightly more expensive ).
and put it on a VFD to slow it down from 400 RPM to about ~ 150 - 200, because i want to cool myself off but without making a lot of noise.
i have been trying to get through to TPI to ask them about this all day but i keep getting the answering machine ...
so let's say if i was going to get the 3 phase version, and then get a VFD that takes 120V 1 ph ( the power i have here ) and outputs 3 ph in the voltage the fan is rated for - how likely would i be to run into some kind of unexpected problem ?
the fan is 3/4 hp so i figure running the VFD from a 15A 120V circuit would not overload it.
as i said i tried to contact TPI but so far no luck - should i try harder ?
I am closing this thread, in accordance with forum rules. This forum is intended to assist electricians, electrical contractors, electrical inspectors, electrical engineers, and other members of the electrical industry with their job-related tasks. If you are not an electrician, then we are not permitted to assist you in the performance of electrical installation work. Engineers are certainly welcome to participate in this forum. I have learned more than I could have expected in the past eleven years. But please restrict your questions and posted comments to issues related to your job.
