azebra
- COLS. OH. USA
480volt, 100' total length, less than 10 Amp draw, parts shuttle. Supply house sent one solid spool, 2 stranded spools, no big whoop on difference in performance?
In the southeast it was a common spec for all conductors 10 and smaller to be solid, pulling was not a big problem.Pulling solid conductors through conduit 100ft is not going to be something I would want to do unless that run was dead straight...
Not concerned about the pull, little concerned with the difference in performance: ie resistance difference between solid and stranded..Based on the voltage, current, and length, I expect that this run is in 12 or 14 AWG, and not a problem for the pull even if solid.
-Jon
Supply house is over a hour round trip away, didn't want to have to add that to the cost of this service call!!Not concerned about the pull, little concerned with the difference in performance: ie resistance difference between solid and stranded..
Sent from my SM-S911U using Tapatalk
Gotta check every item ya get these days before ya leave the supply house...Supply house is over a hour round trip away, didn't want to have to add that to the cost of this service call!!
It will not matter at your load and distance.Not concerned about the pull, little concerned with the difference in performance: ie resistance difference between solid and stranded..
