For a new installation in a quarry I have to run both a 4.16kv and 480V cable out to a piece of equipment. The length of the run is about 300ft. The type of cable that I am using for both runs is 3/C Type GC for the 480V cable and 3/c SHD-GC for the 4.16kV
Both of these cable runs will be run together on the ground for the 300ft that I mentioned above. I am going to try to keep about a 1ft seperation between the cables for the entire run.
My question was weather or not I could possibly have any problems with running these cables together like this, with possible induction or some other problem. In theory I am thinking that because these cables are in a 3/c arrangement, the magnetic fields of each phase should cancel out within a cable therefore not posing any external field to the cable lying next to it, specifically when looking at an external field from the 4.16kV cable onto the 480V cable.
Does anyone have any thought or issues with this installation?
