deb4523
- Alaska, USA
So... two heaters were purchased (without anyone checking with our team) that require 36A each on a three phase 240V system. We have three phase 208V power available. :roll:
Is it going to produce less heat or draw more current?
Do I need to install buck/boost transformers to boost the voltage or will it run as is?
Will running on a lower voltage shorten the lifespan or potentially damage elements within the heater?
Thanks and Happy New Year!
