Are you're asking about the possibility of running the EGC on the outside of the conduit?Can someone point me where in the code says the ground wire needs to run with the feeder wires in the same conduit? Thank you
yes, the design changed and requires an upgraded ground wire.Are you're asking about the possibility of running the EGC on the outside of the conduit?
Sounds like a change order.yes, the design changed and requires an upgraded ground wire.
