We have a VFD on a 200-hp hammer mill (HM; milling wood chips). Motor: 3-ph/60 hz/1790 rpm/219 FLA/96.2 efficiency.
The mill is designed to run at 1790 rpm (issues if rpm slows down to much with hammers rocking on the pins, etc). Thus, I am pretty sure my PLC guy should set the VFD to run at 60 hz (currently set at 55 hz; which I think = about 1640 rpm, correct?) and then set our infeed conveyors to slow down
when HM amps spike above 210 for more than 2-3 seconds. Since this is a guess (both max amps and seconds above those amps), I'm seeking input/suggestions.
Our over-arching best-case scenario that we try to accomplish (never happens; just a goal) is for the infeed to be constant (material dropping off a conveyor into the HM at a steady rate), which would result in the HM running at a constant amperage; That would be too easy. Thus, since this can't happen, we intrinsically have amp-spikes that we have to accommodate. Just trying to figure out best way to go about handling this to maximize motor life, reduce total energy, etc.
Thanks.
Thanks.
