ABoshant
- Bakersfield CA US
I can't say I've ever thought to do or will ever do that. I've always went up and over, around, basically whatever it took to keep it concealed other than drilling the post.
I don't see any reason why that wouldn't be legal however.
Or they may flatten it a tad bit.As the others stated, up and over would be better. But, if this is the only way possible, I would have run it down low against the floor. Much easier on the sheetrockers and easier to conceal behind base. As it is now they have to try to cut around it, then build up andand feather out their mud to try to make it disappear. Not doubt there would be curse words thrown in your direction.
Or, they may cut it out all together and not let anyone know!
Not pretty but NEC compliant.
You know a 7/8" hole saw would make a hole in each side of the column and you could pass through it.
Might even take less time then going to get the pipe, bender, hack saw etc.
Ahh ...Yeah I would steer away from cutting any holes in that structural support column.Wouldn't that column be considered an engineered structural support? I'd be really hesitant about cutting holes in it until I have the blessing from someone who can make that call.
Came around the corner once just just as a plumbers apprentice finished hole sawing a 4" hole through a triple wide micro lam. Not a good day for the plumbers. :slaphead:
