I have a situation where I want to add 2 3-way dimmers to an existing system. Existing setup has EMT going from panel, to a 5S box, and up to two 3ways via wiremold, it then continues out of these 3ways to track lights. I want to run EMT from said 5s box and up to another set of 3ways in another area of the room. So, I'll need to pull a hot, ground, and 2 sets of travellers for the switches.
Now, even though I won't utilize it, is it required to pull a neutral along with these conductors and just cap it off in the box? My reasoning is that the code requires a grounded conductor with all hots, but it seems sort of pointless in this case. What about net current, EMF effects, etc? I think I may run it anyways in case they ever want an outlet or anything, but is it a code requirement?
Thank you for your advice!
[ March 31, 2004, 06:32 PM: Message edited by: mhulbert ]
