Fladude38
- United States
Hello, all.
I have a general question about running romex through beams. Is it allowed to be run through open air voids/drilled holes in concrete beams, block and similar?
I can't find anything regarding this but believe its covered under 334.10 (A) but I have co-workers telling me its not permitted unless its run through a conduit. The only thing I can find is if its within 1-1/4" of finish and subject to physical damage.
The scenario; I'm running cable through concrete beams, drilled out to 1/2" to run through. Its above finished ceilings and nothing is exposed. They are drilled in the center of the 18" beams and run from interior room to interior room, nothing in wet or damp locations. Would this just be in line with parallel beams and framing members?
I've heard quite a few "Opinions" but nothing in the actual code has been presented to me. Is this a case of "Since its not specifically covered, its not a problem"?
Any help would be appreciated. Its not a big deal but I'm a geek and like to know what the code actually says not just opinions.
