Lou N
- Crossville, TN
- Handyman
All,
I'm in the process of rewiring/adding can lights to my unfinished basement. The ceiling will be painted as is, no drop panels or drywall. I'll be using the basement space for a model railroad. Nevertheless I inherited some of the previous owners mess.
In the attached pic you can see a horizontal NM wire run which drops down to individual receptacles. I know you cannot run the NM perpendicular to the joists as it is now.
I think there's enough slack so that I can pull the staples and run the wire horizontally along the edge of the sill plate. Would that be in compliance with the code?
The ceiling in that area is about 8 1/2"
Thanks,
Lou
Thanks,
Lou
