I am working on a renovation for a customer of mine presently. He wants to be able to install a garage door opener in his detached garage in order to make the sale of the house more attractive to a buyer. My concern is; and I have looked in the NEC; is it code for me to run this one 20amp circuit from the house to the garage above a walkway with EMT.
A little more detail. The house sits right next to the detached garage. There is a walkway which is about 4 to 5 feet wide between the house and the garage. Surrounding the garage and going up to the house is cement so going underground from the basement of the house and up to the garage is not possible. The garage sits back a bit further on the property than the house and if you draw a line from the garage to the house it leads to a wall in the living room in the house about 6 feet up off the floor. What I want to do is run a 12 gauge romex up from the basement into the cavity of the living room wall then out a hole in the wall to the outside and mount a waterproof single gang box on the outside wall. From there run 3 12 gauge individual THWN conductors (one hot, one neutral and one ground) through EMT (Using compression fittings) into a hole in the side of the garage then into a junction box in the garage on the wall. From there run Romex to a receptacle by the garage door (inside the garage) put in a GFCI then from there run one light and then one receptacle up in the ceiling of the garage for the garage door opener. Simple, but this way he can list the garage as having power and a garage door opener.
I do know that if this EMT was going over a drive way that there would he a minimum height that this must be but this is simply a walkway. The EMT would be about 8 feet up off the cement walkway.
This is a very small town that uses an independent electrical inspection service. The owner of the property does not want to call the inspector to ask this specific question (long story). So the owner feels that if we do it to code it should be ok.
Does anyway see anything wrong with this setup. I have given it some thought and it seems fine to me. Since I am only running one 20amp circuit to the garage a sub panel in the garage would not be necessary in this case.
Any thoughts or obvious code violations that anyone can see?
Thanks
Thanks
