rookie4now
I have a client that wants power to their garage. I had planned on running #6 quadraplex and placing a sub panel, but he doesn't really want that or the associated expense. I know that practically speaking I could run 12/3 UF for the two circuits he wants. I was thinking I could put an aircraft cable as a messenger wire and wire tie the 12/3UF to the wire. Is there a code problem there? I couldn't find anything one way or the other. Also, I was assuming I would need a ground rod, but I'm not setting a panel so where would it be connected?
Thanks
Thanks
