Re: Running Threads
The reason running threads are used (and usually against the NEC) is when you can't screw the conduits together. You thread one pipe a little longer, screw a coupling ALL the way on, fit the pipes together and finally unscrew the coupling onto the other pipe.
Normally this is where you use an Erikson or union to connect the pipes.
