Corysix7
- Lakeland florida USA
Is it allowable to use a running threaded nipple with a bonding bushing that contains service conductors installed at a meter can enclosure?
Why shouldn't they be? Like the conduit or the regular coupling they have threads and they have galvanizing they shouldn't really have much different effects from environment than use of a regular coupling.Are ericksons even permitted below grade? Not concrete but in the earth. I didn't think they were
I think that we've discussed that before but since a standard coupling isn't water-tight either should it really matter?I know what I was thinking. I was thinking of the threadless fitting. I believe they are not rated for wet location.
It shouldn't but apparently it is important that EMT fittings are the newer rain tight type.I think that we've discussed that before but since a standard coupling isn't water-tight either should it really matter?
IIRC someone decided the original compression fittings we commonly used were not actually rain tight, so they modified the design and included the nylon ferrule that is pretty typical and added a rubber washer to be used at the shoulder of connector fittings and got it listed, making it a violation of listing if you don't use this type of fitting for the application.Good point, I wonder what the substantiation for that was, did it start as a UL listing thing?
I stopped using the rubber washers after first year or so of those type being required. Come back to jobs I had done and find the washer deteriorated in the sunlight cracked, missing pieces, or even completely missing and finding a connection to the box that leaks more water than if I had used a set screw fitting, let alone it has no effective bonding to the box at all. I gone back to putting them into myers hubs to solve the sealing washer issue.
I'm sure it works, at least for longer time than the rubber washers. I'd bet not many inspectors would approve it though. I wouldn't think they can say too much if you install the rubber washer then put silicone over them.I saw a recommendation to use silicon RTV as a thread compound and have been doing that instead of that useless washer. Shouldn't effect the bonding since you can sock it down. Haven't had the opportunity to go back anywhere to see if there was any leakage.
-Hal
