Hello,
I run a small renovation company specializing partially in basement renovations.
To date we have run wire the traditional manner,wall mounted devices through studs, ceiling mounted devices through joists etc.
Every basement reno we do involves a removable ceiling drop or not.
On a current project we had an epiphany (simple as it is) to run all wiring regardless of device mounting location in the ceiling joists. This would allow an often simpler installation and faster install time, then running cable through studs and provide a much more servicable installation if the home owner should ever wish to move a device. Cable would drop into each respective stud bay via the ceiling.
It would for some runs, require more cable per run but other then that I can't think of any other negatives for this type of installation. Am I missing something?
Thanks in advance for your time!
Michael
Michael
