Don Power
New member
- Silver Spring, MD
I have a customer who contacted me about water getting into their electrical panel. They live in a townhouse row which consists of nine other units. The meters for all ten units are on the end of the 1st unit. When the units were built (1980's) EMT was used to feed each townhouse. The EMT was buried in front of the units. Apparently the water is getting into the conduit and eventually into the panel. I told the owner there may be a more dangerous problem, if the EMT is badly rusted there may be danger of losing the bond. There is no bonding conductor pulled into the EMT. Is there any accurate test which can be performed to test the resistance of the EMT from the meter bank to the townhouse? This distance is approx. 250'. Does anyone think I'm over reacting? The rusting could be a problem with all the units. I told him to check with his neighbors to see if anyone else has a water leaking problem.
