Im needing to replace 1 of my roof top ac units ... currently my system is 2 - 13,500 btu 115/20 amp units ... Each on its own 20 amp breaker ..... For a few dollars more I can get the 15,000 btu unit .... The specs are
- Capacity range of this series (BTUs) 15,000
- Power (V/Hz) 115 / 60 / 1 Ph When I talked to the distrubiter, they said it needs 30 amps on start up ???? and then drops to
- Compressor-rated load amps: 13.2 ...... Will this work with the 20 amp circuit ????
