storeytime
- Texas
I have been asked to design and install the electrical system at an RV park. I have never done it before. I have read all the posts I could find here. I'm just not sure as to the best way to design it for this layout. It has 15 spaces. RV electrical box with 50A, 30A, and one 20 amp GFI. Each receptacle has its own breaker in the box. The service is situated between space 3 and 4 about 60 feet perpendicular to the line of spaces.
I had planned on feeding one line (1 - 3) with one conduit run and then one conduit for spaces 4 - 15. The distance between the 3rd space and 15th is about 420 feet. They are all laid out in a straight line. I'm just not sure (due to no experience on these systems) if the best way economically is to feed each spot in line with large enough wire to account for voltage drop or place a sub panel or two along the way. Also, the owner had picked out a box with pedestal that costs much more than just the box mounted on a wooden pole support. Is there any advantage, electrically, to using the pedestal such as lug size, etc.? I appreciate any help.
PS - This is in Texas, very hot temperatures, so I don't know about the demand factor.
