RV Park Site Power, Tap Rules?
Craigv
Can tap rules be applied to RV park power pedestals with feed-through lugs? My assumption/understanding is a hard "no", because the tap ends at a feedthru lug block and not at a "single OCPD" as specified in code. But I have seen such wiring....200a panel supplying 6 pedestals with 4/0 cable to the first two 50/30/20a pedestals, then 2/0 to the next two, and #2 to the remaining two. I can't find any supporting code for this.
don_resqcapt19
Illinois
retired electrician
551.74 says the overcurrent protection rules in Article 240. The feeder tap rule in 240.21(B)(4), requires, as you stated, that the tap conductor terminate in a single OCPD with a rating that does not exceed the conductor ampacity.
