lakewaymike
New member
I am preparing to install 22 R.V. Pedestals in a new R.V. Park. I plan on splitting them up where I have 2 sets of 6 sites on a 200 amp disconnnect for each set. And I will then have 2 sets of 5 sites with 200 amp disconnects for each set. In Article 551.76 (d) it states no connection to a grounding electrode shall be made to the neutral conductor on the load side of the service disconnecting means or transformer distribution panelboard. Does this mean that my grounding conductor that I run with the feeders must be terminated on a separate ground bar installed in each 200 amp main disconnect that is connected to a grounding electrode and not on the neutral bus? This sure is confusing. Thanks
