E enireh Senior Member Location Canyon Lake,TX Feb 21, 2016 #1 1955 rv came with two prong cord works fine unless I hook up cord with a ground then gfci outlet trips without ground gfci doesn't trip
G GoldDigger Moderator Staff member Location Placerville, CA, USA Occupation Retired PV System Designer Feb 21, 2016 #2 enireh said: 1955 rv came with two prong cord works fine unless I hook up cord with a ground then gfci outlet trips without ground gfci doesn't trip Click to expand... Either you have dangerous leakage to ground in some of the rv equipment or there is a connection between neutral and ground inside the RV. Which is it? An ohmmeter will tell (with the shore power disconnected!)
