Rx for 12v applications
I was wondering if you could use existing Rx or UF and convert an existing 120volt lighting set up to 12v. All othe nec codes being considered. If you want to replace 120v cabinet lights with Juno track 12 Lights. Something like taht.
I have used 12-2 NM cable to feed 12V Juno track in the past. Just cut off the ground and keep the runs very short.
