steve gottwald
What would the voltage drop be from supply(power pole) to breaker panel using 3/0 copper in a 450 foot run be.(200 amp main)
steve gottwald said:What would the voltage drop be from supply(power pole) to breaker panel using 3/0 copper in a 450 foot run be.(200 amp main)
You don't need the circuit voltage to find the voltage drop...you only need that to find the percentage of drop.480sparky said:And the voltage.
brian john said:You guys SOOOOOOOO complicate everything.
