Ravenvalor
- Piedmont region of NC
Hello,
I just purchased a FLIR ONE PRO LT in order to inspect a 1940s era church that has fuses and the old BX cable. I plan to introduce a load to the various circuits by plugging in one or two 1500-watt space heaters into the receptacles. Could someone please recommend some temperature maximums that I should be looking for at the screw terminations on the receptacles and on the circuit breakers? Is it safe to assume that the plastic breakers are almost opaque to infrared so I cannot depend on an accurate reading by measuring the plastic on parts of the breakers?
Thanks for the help. I appreciate it.
