We have a bit of a debate going at my workplace... when opening 4KV switchgear @ a large motor control housing, should one stand to the side of the cubicle door or in front of the door. Most of us maintain that you should stand to the side. One guy insists that he is an electrician and you should stand in front of the door so that if the Switchgear flashes it will blow open the door and blow you out of the path. He maintains that if you open from the side the door could blow open & part of your body would be exposed to the flash... comments?
