Re: Safety Harness and Equipment
the prusik can be hard to tie for an untrained person, as well as any safety knot tied where one's own life is dependent on it. Usually there is no one there to say "that's it".
The modified prusik can be tied with one hand. It is tied with the long bitter end of the bowline (that supports the harness, bosun's chair, saddle). The other long line leaves the bowline and travels over the life support (branch, beam, caribinier, whatever) and back down to be tied to the bitter end with the prusik. it is a long loop with two knots, one a bowline supporting the harness and the other, the prusik tied within short reaching distance from the bowline.
The idea is that the knot will not slip unless it is straightened by hand as weight bends the line and holds the loop fixed. That is the theory. In reality different types of rope behave differently.
As a climber, I tied the knot with two turns below and one above, instead of two below and two above. I found it gave me more control both rising and descending. I tied it tight. I have seen the prusik let a person drop twenty feet before they could let it go, and that makes a really hard stop on some rope. if the prusik is tied too loose it won't run, and if too loose, it runs too fast. And i still believe that safety lines should be practiced until confidence is established.
Sorry i do not have the access to what it takes to uplift pictures.
paul
