During a safety walkthrough it was noted all the safety showers and eyewash stations do not have drains. In the same report it was noted there are flush receptacles in the floor.
Yes, the power was there first, the shower/eyewash installed later. This was my first fact verified. I know the NEC directs us to maintain distance or install GFI's around water. Doesn't a plumber have a set of codes which may say something like "Its bad, to spray or flood anything with water, which has live electricity? ( OK, BAD HUMOR )
Real question... Is there a exception loophole for safety showers / eyewash stations which are undrained? I have already read the scripture iaw NEC70, and found none....
My solution initially was GFI CB's but also found 3PH 480 in one of the floor
j- box's with junctions. Looking for a cheap/simple solution.
Thanks in advance
Thanks in advance
