Pierre C Belarge
- Westchester County, New York
This is a story related to me by an electrician yesterday. It is amazing what can happen when current travels through our bodies.
At the end of a day, the electrician was preparing the ends of some MC cable for the following day. He scored the MC cable so that the next day all he would need to do is remove the sheath and enter it into his fixtures. The supply end was in the panel. Someone else had terminated the panel side, but had the breakers turned off.
At night, the maintenance guys saw the breakers off, so he turned them on.
The next morning, the electrician did not check for voltage and started to remove the sheathing. One hand on the cable sheath, the other hand to remove the cut portion of the sheath. The 277V went from one hand, across his shoulders past his neck and to the other hand....very, very bad.
The current did not pass through his lungs or heart, but across his shoulders and neck. His muscles contracted so violently, that he broke 2 vertebra in his neck. He survived the incident, but has permanent damage.
I thought it was an interesting story in regards to how this stuff can do some crazy stuff to us.
