elecrookie
- Baltimore
Hello to Everyone
i found this question and i was totally confused , maybe i just don't understand the question and looking for HELP question below thanks
1. A balanced 3 phase, 60Hz load consists of machinery of 500 kva at 0.5 PF lagging, and a 3 phase resistive load of
300 kW. The two loads are supplied by 4160 volts feeder.
a. What is the magnitude of the feeder current?
b. Specify the number and ratings of the capacitors required if it is desired to improve the feeder power factor to
0.8. Assume caps will be connected in Y.
