Satellite bondiong
tomradtke
I have gone over the Grounding versus Bonding Book and CD's. I am still not clear on ground blocks/discharge unit. Are they both the same?
Also the location of the ground block/discharge unit. The book states "The location of the antenna discharge unit must be located outside or inside the building, nearest the point of entrance,but not near combustible material". If this is the case, can I run the bonding conductor in conduit to a grounding/bonding sourse?
I thank you for all you help.
Thomas Radtke
Lead Field Technician
NRTC
(Moderator’s Note: Edited to remove phone number. If you wish to contact this person, then first send a Private Message via this Forum, and ask for the phone number or email address.)
