I have a eave mounted Satellite mast with a #17 copper coated wire running to a coax ground block about 28' feet away. From there I am about 36' from the electrical service ground rod. I am considering driving an 8' ground rod near the coax ground block and running 2-#10 copper (one for the mast and one for the coax) to the new rod and then running #6 copper from the new rod to the electrical service rod. Do I need both #10 wires to the new rod to meet NEC code? Should the #6 copper be buried and if so how deep? Any other suggestions? I can not relocate the mast or the point of entry for the coax.
