The satellite installers just mounted the dish on the roof and grounded it by running a # 10 wire to an outdoor fixture where they picked up the 14-2 romex ground in the box. I kind of chuckled and asked them what they were doing? Shouldn't you guys ground the dish to the electrical system grounding electrode conductor and with a much larger size conductor? The young men responded that they usually do, but the GEC is clear on the other side of the house. I said will then lets get under the house and route at least a #8 bare solid copper conductor to the GEC. They said that they were trained not to run the dish ground farther than 25 feet between the dish and grounding point of attachment and that this method is acceptable to Dish as they were trained.
Does anyone know the actual installation method to properly ground the dish?
Thanks...Dan
Thanks...Dan
