RampyElectric
- Liberty SC
There seems to be some confusion about whether or not the exams are PSI or Thomson Prometric test..... both. Thomson is with the municipal associations (j-man, county, city and contracts under $5000) and the labor board (anything over $5000) is using PSI. I only have a j-man, but I can tell you that you will see little or no calculations and obscure code questions dealing with MAX/MINs. This is the Thomson test. When I take the PSI one I will try to post.
