mstrlucky74
- NJ
When would one use/work off scaffold instead of lift? Thx
Sent from my SM-G955U using Tapatalk
I have a job coming up to replace 400 watt HID's in a gymnasium with LED's. Scissor lift would be really nice. They won't let me bring one in there unless I lay 3/4 plywood on the floor to run it on. Doesn't seem worth it compared to just using scaffolding that they will let me roll on the floor as long as wheels are in good condition and won't damage the floor. They will have a thin protective cover on the floor either way, but already have this and use it whenever there is other then athletic activities happening on that floor.
Finding a rental scaffold with good Wheels is going to be about as difficult as maneuvering sheets of plywood on the floor if they don't scratch the surface... I would think it would be almost impossible to turn a manlift on top of plywood without the plywood pivoting under the tires and scratching the floor.. then again, most gyms have pull-out bleachers and those wheels have quite a bit of weight on them and they do not damage the floor.
Given that you're going to burn extra time safely moving either, I would rather have the time advantage of a lift in your case. Your helpers on the ground can move plywood in between unboxing new fixtures and taking old ones out
Not quite sure what you mean about plywood pivoting. I know that it isn't an issue with 3/8" masonite. Personal experience and recent. Within the last year.
the lift cracked the very expensive tiled floor.
If I have the lift I don't need a helper. With scaffolding I will need to climb at each light location, doable but not so desirable for fat middle aged menI have found that it isn't that big of a deal to move 4 x 8 sheets around. I would seriously question 3/4" plywood and explain it is actually more likely to hurt the floor in the event of mishandling and 3/8" masonite will hold up to the wheels of a lift all day long. I would be concerned about the scaffold, because what is described sounds like there is still potential for damage to the floor and who will be nailed for that. With the lift it is likely you just have a helper on the ground to box and unbox and to move the sheets of masonite as needed.
And I did some repair on a warranty basis recently.
Floor under bleachers when pulled out isn't quite as guarded at this place, main court they are very particular about. When we ran lift on plywood a couple years ago we had no problem with plywood trying to pivot when turning. Not going to happen if you have more then one wheel on a sheet. even if you only have steer wheels on one sheet - if butted up against another sheet with the other two wheels on it - it can't really move because of the weight on that other sheet won't let it move.Finding a rental scaffold with good Wheels is going to be about as difficult as maneuvering sheets of plywood on the floor if they don't scratch the surface... I would think it would be almost impossible to turn a manlift on top of plywood without the plywood pivoting under the tires and scratching the floor.. then again, most gyms have pull-out bleachers and those wheels have quite a bit of weight on them and they do not damage the floor.
We used to run large scissor lifts over 1/4 in masonite on wood floors with no problems. I agree that tile would be a problem, and also to inspect the wheels well.I have found that it isn't that big of a deal to move 4 x 8 sheets around. I would seriously question 3/4" plywood and explain it is actually more likely to hurt the floor in the event of mishandling and 3/8" masonite will hold up to the wheels of a lift all day long. I would be concerned about the scaffold, because what is described sounds like there is still potential for damage to the floor and who will be nailed for that. With the lift it is likely you just have a helper on the ground to box and unbox and to move the sheets of masonite as needed.
