S spiderman_00 Member May 8, 2005 #1 please explain in architectural drawing for 1:50 and how to use in electrical plan
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician May 8, 2005 #2 Re: scale 1:50 is normally a civil scale. 1 inch on the drawing = 50 ft on the ground. Get a civil engineering rule and use the 1:50 scale
F frank2004 Member May 9, 2005 #3 Re: scale Are you sure this is not a metric scale? If it is a metric scale the U.S. equivalent would be approximately 1/4"=1'-0" which is 1:48. Hope this helps. Frank
