When labeling control panel per UL508A, the label shall include short circuit: __ka and voltage ___ maximum.
Question is, should the voltage on the label be the rated voltage of components or the voltage for the panels intended use?
For instance all components in power circuit are rated 25ka @ 600v, but panel is intended for use in 230v application. Should SCCR label read 230v or 600v?
thank you,
thank you,
