Here we go, as best as I can explain. The UL testing of a device uses wire of a certain size, fuse of a certain type & rating, and etc. So long as the device is used with these same parts in accordance with the UL listing, and per the manufacturer's instructions, then the SCCR rating be per the manufacturer data sheet. Where one gets into trouble is if you install the device, and don't follow all of the manufacturer instructions. Hope this is clear and helps.
Edited for some serious clarity issues.
