Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
Most projects I worked with kept the type of pvc consistent for the entire run. However I was wandering that due to cost what are some thoughts of going schedule 40 pvc for underground trenches to run wires and exit schedule 80 for exterior protection of wires. Obviously the inner diameter will be reduced on the end portions of the run in order to protect the wires and may affect pulling difficulty, overall conduit fill limitations, etc etc. also there is no special coupling fittings for this and the bell ends of the Taylor different rated PVC will connect correct?
