jeff48356
- Livonia, Michigan
Consider a room addition onto an existing house with a detached garage being built in the back yard. The garage is to be fed using a 40A 240V feeder. A junction box is to be installed in the crawlspace, which will be attached to 3/4" PVC conduit which leaves the crawlspace (above grade), and goes down to a trench 18" deep toward the garage, and back up into it. The PVC will extend all the way into the bottom of the subpanel for a feeder. Which parts need to be schedule 80? Or would Sch 40 be acceptable for the entire run?
