Houston714
- Nashville Tn
Hi all! I've got a 285 ft. run for a 50 amp RV outlet. The situation is different due to voltage 120/208 single phase.
1. Are not most all RVs 120 Volt loads?
2. Should my Calculations be based on 120 not 208 sing phase?
My Calculations came out to a 1/0 Aluminum Stranded 4 conductor at 3%.
If I did a 30 amp 120 RV outlet it still calls for a 1/0 Aluminum Stranded 3 conductor at 3%.
Thanks for the help!
