bkludecke
- Big Bear Lake, CA
- Retired Electrical Contractor
I know it varies from area to area, but what are you folks getting for insulated scrap wire (per lb). I don't have the time or inclination to strip it.
bkludecke said:I know it varies from area to area, but what are you folks getting for insulated scrap wire (per lb). I don't have the time or inclination to strip it.
Dave85 said:I'm not sure about the price around my area but I as well don't have time to strip all the scrap wire
however I have been looking to make a motorized wire stripper that you would be able to feed wire into and it would slit it down the side and all you would have to do is pull the rubber off of it.
I photoshopped a simple plan up in my spare time this weekend.
http://s2.photobucket.com/albums/y2...tripper/?action=view¤t=Wirestripper.jpg
Using the MiG welder I would make a small metal frame which would hold a pulley with rubber covering in the track (Red)
the chain and motor would drive that.
As you can see the frame also holds a utility knife blade which will strip the wire down the side.
Speed will be fairly slow and a bunch of safety guards will be be put up in the actual design.
