jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
I recently replaced wire in s corroded but intact conduit. I found how water had gotten in an sealed it off, also drilled small weep holes in the main j box and 2 LB’s.
I would have replaced sections of conduit but most areas of the run were not practical for this. I pulled rags through several times, 1st few soaked with h WD40. Then 3 with water & last one with Clear Glide. Did OZk but still tough.
I’ve seen wire brushes online for pipe. Has anyone ever tried this? Might work to pull a brush through & blow out with a vac.
