screw down connectors
skosik
New member
I've heard that using stranded wire is not suitable for these type connectors.
Solid type should be used.
Is this correct?
Stephen
Re: screw down connectors
Stephen,
To get a good answer to this I think you have to explain a bit more what you mean by screw down connectors. Give an example if you can so it's clear to everyone.
Bill
While we are waiting for a more clear question I will add that many screw down connectors are only rated for one or the other. Some are rated for both solid or stranded.
Generally speaking for stranded there is usually something to prevent the screw from destroying the strands as the screw is turned-- something like a washer or something like a mash plate.
It comes down to the listing on the connector. Post back with more details and we can give you a less generic, and a better & safer answer.
